Het is nu vr 26 apr, 2024 13:33
 Berichttitel: HY78 123 ignition on a hy72 motor
BerichtGeplaatst: zo 30 sep, 2012 16:39
Woonplaats: deer isle , maine
can an hy78 123 ignition be used on an hy72 motor? is there a special adjustment for the timing? the rotor arm on the 123 looks like it is about 15 degrees off from the s.e.v. distributor,will this make a difference in the timing?
many thanks to anyone who can help!
-gregor
-lelijke Amerikaan
 Berichttitel: Re: onstekingstijdstip hy72 anders als hy 78
BerichtGeplaatst: zo 07 okt, 2012 0:32
Is this the correct area to ask about 123 electronic ignition problems ? Can someone tell me where to look if it is not correct? Thank you
-Gregor
-lelijke Amerikaan
 Berichttitel: Re: HY78 123 ignition on a hy72 motor
BerichtGeplaatst: zo 07 okt, 2012 0:50
Hi Gregor,
I'd say it would be the same, as the main difference is the cilinder volume, so timing should be the same. But I'm not sure... maybe contact http://www.123ignition.nl/id/8.html
BerichtGeplaatst: zo 07 okt, 2012 8:42
Do you have the dip-switches on your 123? The manual sais which setting you need for the engine.
BerichtGeplaatst: di 09 okt, 2012 1:43
Thank you both , very helpful! This seems to answer my question, leipe
-gregor
-lelijke Amerikaan
