Het is nu do 18 apr, 2024 2:18
 Berichttitel: 123 ignition for 1966 HY. H72 engine
BerichtGeplaatst: di 17 jan, 2023 5:06
Geregistreerd: zo 12 jul, 2020 23:52
Hello All,
We are looking for the correct 123 ignition for a 1966 HY van with the H72 engine.
There is a 123/DS-R which fits the HY van with the H78 engine. Does it also work on the H72 engine?
Hopefully one of you have installed a 123 on a H72 engine.
We appreciate your advice!
Kind Regards,
Kat & Garric
 Berichttitel: Re: 123 ignition for 1966 HY. H72 engine
BerichtGeplaatst: di 17 jan, 2023 16:07
Woonplaats: deer isle , maine
yes.
-lelijke Amerikaan
BerichtGeplaatst: di 17 jan, 2023 18:13
Thanks for your prompt reply Amerikaan!
BerichtGeplaatst: wo 18 jan, 2023 0:37
Our HY van has an SEV distributor. Will the 123/DS-R work. Or will it only work with HY’s that originally have a Ducellier distributor?
BerichtGeplaatst: wo 18 jan, 2023 19:33
The hole in the engine is the same.
You replace the whole ignition with 123, so which brand it was before is not important.
Pay attention to the drive axle, the notch and rib are not in the middle, it is not symmetrical!
It is possible to place the axle 180 degrees wrong in the engine with some force. But then the ignition wil damage.
BerichtGeplaatst: wo 18 jan, 2023 19:55
Thank you Joost,
Best,
Kat & Garric
BerichtGeplaatst: do 19 jan, 2023 4:08
also be sure to select the correct setting for your hy on the 1-2-3 unit befor installing ,there are two options for it. i will check the correct number and report.
-lelijke Amerikaan
