Help de voorste draaibalk
stable
Bericht door stable »
Eerste hallo uit Wales UK. En excuses voor onze verschrikkelijke politiek.
Ik heb ook een slechte opleiding.
Ik herstel bij H van. toen het aan één kant kwam, zat het lager. Ik heb het 'paard' verwijderd en er is iets vreemds aan de draaibalk ... Ik neem aan dat iemand ermee heeft gespeeld? Zoals je kunt zien aan de eindkap. Deze kant zit laag. Kan iemand adviseren? Dank u. Tom
First hello from Wales UK. And apologies for our abysmal politics.
I also have to use google translate as our education system is so bad.
I am restoring a H van. when it came to me one side at the front was sitting lower. I have removed the 'horse' and there is something strange about the torsion bar... I assume someone has been playing with it? As you can see it is sitting back at the end cap. This side sits low. Can anyone advise? Thankyou. Tom
Re: Help de voorste draaibalk
It is possible that the torsion bar is loose from the splines in the big tube. So you have to dissassemble the lower front suspension/torsion bar and rebuilt it. Instructions in the service manual are very clear.
I do not envy you concerning the Brexit policy, but in our country things are not much better, Perhaps that is a relief.
stable
Thank you, in both respects!
Can you point me towards a service manual covering these details, I’m finding it hard to find information.
Tom
I can pont towards the Dutch documentation for you:
https://site.flyinghy.nl/document/index
https://site.flyinghy.nl/docs/handelingen/H78_433-1.pdf
Maybe google translate can be your friend here as well? :)
stable
Thank you that’s a great help. I wonder if the bearings have become displaced. Does anyone know there size?
if you send me a private message with your mail, I can provide an english parts book
stable
Message sent, thank you
I sent you documents with WeTransfer a few days ago.
Joop
Kenteken: 37 83 rb
Bericht door Joop »
stable
Having trouble finding out the bearing sizes or supplier - seem to be missing from both sides :?
everything is available via the club (HY magazijn) . You have to be a member, its is worth the money
